68 GT350 Vacuum Canister Location
Started by Smity, November 23, 2020, 05:24:38 PM
Smity
Does anyone have a photo of where and how the vacuum canister for the swing-away steering column is mounted under the battery tray?  Any help would be much appreciated.  Thanks!
Quote from: Smity on November 23, 2020, 05:24:38 PM
If your car had tilt and the panel is original then it should be obvious when you look under the battery tray area. If installing tilt on a previously non tilt car or a original replacement panel then there should be som locating dimples for the the two mounting studs and the center vacuum nipple . If a aftermarket replacement panel then you will have to estimate the location . It isn't super critical. I posted a picture of the dimples on a original panel to use as a reference. I hope this helps.
Early cars did not have tilt, so please take that into account as well.
Corey Bowcutt
Smity
