GT500KR disassembling exterior mirrors
Started by Jack4159, November 27, 2020, 10:19:11 AM
KR500
Quote from: Jack4159 on December 01, 2020, 08:24:58 PM
Thanks Bob, Pete and all.
Ok I'm sitting here mirror on workbench and if I think I can get it apart I will have a go, have the lot rechromed and stay original.I have the time so that is not an issue, I just don't want to butcher it.
Now, how do I release the mirror as Bob suggests? Heat, to free up the glue? If I get the mirror off I then could dremel grind off the mounting points for the control cables and the rest is cake?....but how to reattach?or is is better to detach the cables at the other end? That looks a tricky task releasing the crimps without breaking the housing.Better to cut the cables at the control knob end and silver solder back in? or can the crimp be opened up?
I leave the mirror glass alone. Disassemble the control end and leave the cables attached to the mirror plate. Getting the part that the cables attache to spread open to release the cables is the hard part. Do Not cut the cables! As noted before mark the location of the cables, they are color coded.
Rodney
Jack4159
Quote from: KR500 on December 02, 2020, 08:47:44 AM
Rodney
Thanks Rodney, I'll post with the outcome if it works out, if not I may keep my head down.
Rodney - where the cables pass thru the chrome bezel, what method do you suggest for spreading the bezel where it pinches the cables holding them in place?
Do you apply some heat? Is there a tool that is good for spreading the metal?
And thanks Jack4159 for starting this informative thread!
KR500
Quote from: propayne on December 03, 2020, 09:15:32 AM
No heat. I use a gasket scraper and a small thin bladed screwdriver. A small chisel might work also. My finger usually do not escape unscathed.
Rodney
Jack4159
OK I had some success, took me about an hour.
I opened up the crimps with a small flathead screwdriver and also used a needle file to tidy up rough edges before extracting wire.
Pics attached will maybe help anyone else who wants to have a go.
The crimps furthest away from the adjustment knob are easiest, so start there as it gets easier with every one you do as you get the hang of it.
Once you have the crimps opened up a little at the end closest to the adjustment knob, get underneath the bullet head and ease it up out of it spot, this takes a little effort. Once it's free pull the bullet head towards the adjustment knob, that will take the head away from the crimp and you will be able to lift the wire up through the gap(which only needs to be opened up to the diameter of the wire).
Once free of the crimps you need to pull the wires out through the housings before you will be able to separate the various housing pieces.
Wear a heavy glove on your left hand, the flat blade driver will occasionally slip due to the pressure you have to exert and attack you viciously. This is very exciting and results in involuntary noises being made....followed by pain and a more considered and prolonged x rated outburst.
Hope that helps somebody out there. :)
I applaud your efforts. I have broken and destroyed many parts to see how the were assembled.
Keeping track of your time is a good idea. Then you can evaluate what the true cost is and decide if it was worth it.
427heaven
 All I can say is WOW. The time, effort, cash outlay for the ability to say, you have an original mirror is outstanding. Not for everyone, so an A for effort on your part! ;)
KR500
Quote from: Jack4159 on December 04, 2020, 07:47:31 AM
I warned you that it could be painful!
Rodney
