68 Rear valance finish
Started by Corey Bowcutt, December 08, 2020, 01:48:45 PM
Corey Bowcutt
I am refinishing the rear valance on my February 12, 1968 GT350.  What should the color/finish be on the back side of the valance?  I am assuming Red Oxide epoxy primer but want to make sure before I do it.
Thank you,
Corey
Yes red oxide
You will have two spots of deadner above the exhaust cut outs.
Corey Bowcutt
Thank you Pete for the rapid response.  I assume the deadener is black because it was applied after the red oxide?
Commonly painted on car, so at least some of mounting screws were also painted.
Metuchen cars all attaching.screws on when painted. Studs loose
68blk500c
Quote from: Corey Bowcutt on December 08, 2020, 01:51:54 PM
original deadener example (generous application, mind you) from #2139 early March car.  FYI
Corey Bowcutt
Thanks for all the information and picture.  Does anyone know why they added the sound deadener there?  Seems odd to me.  The only thing I can think is protecting the paint from heat?
Quote from: Corey Bowcutt on December 08, 2020, 08:44:27 PM
Not heat but vibration cause by the sound coming from the exhaust tips .
Rukiddin
#9
Another example of the sealer at each side near opening. Looks like a thin brush application covered by a heavier sealer.
KR500
