Correct starter part number for 65 GT 350?
Started by DRGT350, December 18, 2020, 03:20:02 PM
DRGT350
Gents -
what is the correct starter number for a May 65 GT 350?
thanks in advance !
Jbarela
Hey buddy this was passed to me from a friend. Hope it helps.
C4ZF-11001-A. It's the same as the "A" code and "C" code engines. The early service stock number is C2OZ-11002-A, later service stock number is C2OZ-11002-B.
EdwardGT350
1966 GT350 6s1761
Part of your challenge is that these were ink marked with the engineering numbers and its likely that has all worn off or been painted over as time passed. You can get them restamped to match your application (make sure you find someone with the correct stamp  ::)once you find one that is physically correct for your application
