Paint colours
Started by 6TY7GT, December 27, 2020, 09:52:46 PM
6TY7GT
My 67 is Wimbledon White and has a Ford paint colour of 1619-A. This is not recognised within Australia and the Marti Report doesn't appear to have a paint code for the black underside of bonnet.
Need assistance with alternate paint code for Wimbledon White and also a code for the black underside of the bonnet.
Thanks Simon
Does your car have the all fiberglass hood?
(Only asking as the metal framed hoods were body color on the underside of the hood.)
Does Australia use the PAL color charts, or is there a primary brand (maker) of paint that might be also used in the USA?
This link references multiple paint makers codes for Wimbledon White, scroll down to "67 Mustang" Line
http://paintref.com/cgi-bin/colorcodedisplay.cgi?color=Wimbledon%20White
rcgt350
Good call JD, Im also looking at an invoice I have here for PPG 8378 after the Ford 1619 code.
6TY7GT
Thanks JD, I'll question the guy that is respraying the bonnet, and patching the paint chips. The bonnet is fibreglass, so black. Is there any specific black, and is it gloss, semigloss or Matt?
  Also: somebody explain the fogging/overspray around the edges of the bottom.  Or post a photo.
T-Bone68
Hi Simon,
I've never seen someone post a paint code for under fiberglass hood black, but here is another thread with good information for you.  You should also try searching at concoursmustang.com.  Generally low gloss black.  I would say stay away from a heavy coat of high gloss black.  Light spray of low gloss seems to be typical and some were left unpainted.  Some good examples of typical overspray in these as well.
http://www.saacforum.com/index.php?topic=8205.0
oldcanuck
Is low gloss black the same as satin black ?
Bob
Knoxvegas, TN
Richstang
Quote from: oldcanuck on December 30, 2020, 08:54:33 AM
Nooooo. Low gloss is about the same as semi gloss.
The sheen is the reflective quality of paint. I think of it in 5 stages from flat to gloss, with satin in the middle.
Flat / Matte (No reflection – lower durability)
Semi Flat
Satin
Semi Gloss
Gloss (High reflection – higher durability)
1967 Shelby Research Group
www.1967ShelbyResearch.com
T-Bone68
Sorry.  I shouldn't have confused with a term like that.  I meant flat or semi flat.  If I were painting mine again, I would choose flat because that seems to be what is on there.  When I see satin or higher gloss I tend to think tribute car.
Any general consensus out there what it should be?  I don't claim to be an expert here, was trying to help by sharing the info already posted.
