Carburetor spacer GT 350
Started by Shell69, December 29, 2020, 07:16:43 PM
Quote from: Shell69 on January 19, 2021, 12:33:09 AM
My spacer came in, 1/4" thick and now I have transmission kickdown rod issue's, it appears its to long.? anyone have this issue?
It may have been changed out. I have a original 351W kick down rod if anyone needs one .
SCJSTU
Quote from: Bill on December 30, 2020, 06:27:05 PM
How about a part number for the correct gasket for this one  ;)
What Bill said.......
Built Jan 1969 Red/Black
2004 Mustang Mach 1
1957 F-100 Fridge
1963 Falcon Ranchero
1961 Econoline PU
1961 Falcon 2 dr wagon
1970 Chevy Blazer 2WD
Quote from: SCJSTU on February 16, 2022, 02:22:23 PM
Good stuff......i'm now looking for a correct spacer too..
Take the Boss 302 version and trim down the metal tube . Once you attach the hose you will not be able to tell the difference. ;) . When using the short tube version be sure to attach the pvc hose first before installing carburetor or risk breaking the tube and spacer like so many did back in the day.
Krelboyne
Found another version? Scooped it up at the Portland Swap Meet today. No barb on the metal tube.
Quote from: Krelboyne on April 01, 2022, 09:40:50 PM
My guess it has been trimmed. You don't typically find a tube on a breather cap, air cleaner base, pcv valve  etc. without the hump on the end to make it so that the hose stays on better.
