1967 starter details
Started by imming1965, January 04, 2021, 02:50:24 PM
imming1965
does anyone have pictures and details about 67 starters for small block 4 speed. I believe i have correct starter housing but not sure about the band and the cover.
When was your car built?
Two different versions were used during 67 productions. The early version was installed through the production year IMHO while in the later production period either the late or early were being installed so best to start out with what time period your asking about
imming1965
Can't make out the date - it's at the end of the bottom line stamping on that version.
On first look of course the paint job is incorrect as pointed out in earlier threads. Fully assembled, painted semi-gloss black with a fading away of paint on the snout to no paint in most or all where the starter attaches to the bell housing and engine plate to ensure good grounding for operation.
Metal plug is a replacement, it is a similar shape to an original depends on how exact you want.  Appears, can see an edge, to be missing the heavy paper gasket under the band
Band machine screw and nut would have been a straight slotted head and a square nut
Going though additional pictures think the electrical stud has a non-factory like gasket and the retaining nut is incorrect but will check
To add to Jeff's observations - Even though your hand is probably covering the ribs   ;) on the 1970 and later nose cone you can still tell it is a latter 70's housing because of the ribs or protrusions that are seen sticking out on the exterior band of the nose cone compared to the all smooth band on a earlier 1960's style nose cone . The band on a 60's part is smooth where as the later parts have the ribs or protrusions along the outside band. It is just easier to explain the rib feature as the most noticeable non 60's feature when searching out a viable vintage part. Even though it is out of sight once installed but you can still tell its a later style nose cone part  none the less .
Maybe these images will help?
I think I got them from this forum in October of this year, they seem to display some of the points Jeff and Bob are discussing.
I can delete them if they are more confusing than helpful...
Quote from: JD on January 04, 2021, 09:56:15 PM
All good except the round back bendix cover which is a 65 early 66 feature.
430dragpack
#7
Here is the correct Mustang small block nose cone, regardless of transmission, until the larger diameter, manual flywheel was used in Mustangs(1968),etc. , C3OF-11131-A, compared to a later style with the strengthening ribs as Bob described.
430dragpack
#8
Here is the correct cover as Bob describes and part of the paper gasket under the band Jeff describes. This is '66 dated, but I can't make out the month.  I have another original big block, ink stamped starter that is dated Jan. Of '66 and it has the earlier cover, so sometime around/after that is the possible changeover for the cover??  Now all he needs to know is when Ford approximately switched to the die stamped housing.  I don't really want to dig through all my starters to look at dates right now, it is a great arm workout!!  :o
  Great pictures.  Now we can get the stamp in the correct location.
Harris Speedster
I have a question;
I measured height of 5 different nose cones.
Why are some taller than their counterparts?
I always kind of though that, auto to a 4 speed car, that rationalization does not appear to be correct>
OR, small flywheel to larger flywheel., which brings in the added strength webs?
BTW, when did the big clutch larger flywheel begin, Bronco ?
John
430dragpack
#11
Quote from: Harris Speedster on January 05, 2021, 12:13:53 PM
John
1965 Galaxies, trucks and probably others. That's why the small block, large diameter manual trans. flywheel(BOSS 302,etc) originally used the C5TF-A nose cone until about Jan-Feb of 1970 with the C7AF-F starter, then went to the DOTZ-A (NO ribs) nose cone at about the same time they started using the D0AF-C starter, replacing the C7AF-F starter. Small block, Small diameter manuals and about all automatics used the C3OF-A nose cone until 1970 model year when the D0OF-A nose cone started then the D2(ribbed)nose cones.  Confused yet? There is also a D0AF-D nose cone for a large flywheel manual that has the ribs, but haven't seen enough to determine their usage, the few I've seen are dated 1972.
Top cone in picture is the C5TF-A, large flywheel manual trans, bottom is the C3OF-A. The C3 is about 1/2" longer than the C5TF from mounting flange to the bushing end. The overall thickness of all the nose cones is pretty much the same at ~3.5".
Second picture is the C5TF-A and D0TZ-A that replaced it.
imming1965
Quote from: J_Speegle on January 04, 2021, 04:51:00 PM
jeff i looked at date and it appears to be may 67 date so just a little late for 1376...so my guess its looking like this would be better for an early 68 car and needs all the other changes mentioned in post replies. thanks for info
imming1965
Thanks 430 these are the details and info i was looking for. A+++ and thanks for all the other replies Bob, JD, and others
430dragpack
If you need a C3 nose cone, I have some extras.
Chris
