Ford Blue engine paint
Started by TS69GT500, January 20, 2021, 04:14:04 PM
TS69GT500
Who is producing the most accurate late 60's (if that makes a difference)  Ford blue engine paint at this time?
Or are the top restorers having theirs custom mixed ?
I have spray equip and a compressor,  so no spray bomb no problem.
TonyS
Corey Bowcutt
As far as spray bombs are concerned I tried no less that 5 different brands and found the OMNI-FILL AP-EB Ford Dark Corporation Blue to be the best match for the color of my 68 302.  But there is no guarantee that my engine is the correct color so by all means get other opinions.
Corey
TOBKOB
There were more than one color of Ford blue paint used... :)
TOB
1969 GT350 owned since 1970
Quote from: TS69GT500 on January 20, 2021, 04:14:04 PM
TonyS
Many restorers use the professional line factory packaged PPG Ford engine blue and then add flattener to adjust the sheen as it is too glossy . Use the search option to get the exact PPG code if your PPG store can't find it.
This might help with using the search function. (If you can't give it an exact name....well good luck on it giving you any decent results).
Anyway, this was in my files;
PPG Delstar # DAR13358 Blue.
I personally have seen three different shades of "Corporate Blue" on original Ford engines.
Using the PPG I suppose to standardize the shade has it's merrits but have doubts as to it's 100% accuracy.
It is my understanding, right or wrong, that the color is somewhat of a "batch color" and varies at least from plant to plant.
Probably the closest answer to your question is to ask someone in authority like a head judge, what they would "expect" to see on an engine, if not even a specific engine series, since the shade does seem to vary for instance from a 428, to a 351 and a 302. Some lighter. Some darker.
"Good luck with that", in determining which is right since I don't think there is any sort of "Standardization", just more common opinions based on observations?
QuoteProbably the closest answer to your question is to ask someone in authority like a head judge, what they would "expect" to see on an engine.
That worked really well on the under carriage, after three national judges chimed in.
Quote from: Coralsnake on January 21, 2021, 09:58:59 AM
It's probably the best advice to give. Some are just looking for standardization where it's entirely possible and arguable that there isn't any?
It doesn't really matter who is right as long as someone is. I'm not the one who needs to be right. I can't speak for others. Many do an excellent job of shooting themselves in the foot without me even encouraging that.  8)
Quote from: shelbydoug on January 21, 2021, 09:51:52 AM
Yes there is a range of slight shade changes. Just like many things that have a range of expectations the concours judges use their expertise to make a call. I suggested the PPG shade and product because first the shade is well within the accepted range of expectations for 66-70 Shelby and two because the two part paint has superior durability.
NPD matched the original 13358 for spray cans.  It probably will hold up ok on cars with minimal use.  There are other options with using urethane with hardener that might be a better choice.  Although, any of these are dependent on surface preparation.
As to different shades of blue, yes that happened, but with age/heat cycles on painted parts over time, that's something that would be hard to say one way or the other...  especially on a restored car.  Also consider that the shade of paint is also dependent on how much is applied and we have seen original paint engines with very little paint to runs all over the oil pan.
Quote from: CharlesTurner on January 21, 2021, 10:37:33 AM
Ah, that leads me to another tech question which I will start a new post on rather then derail this one. ;)
TOBKOB
On my car I was able to take the snorkel off the air cleaner and match to the unexposed original paint between the two parts... :)
TOB
Quote from: TOBKOB on January 21, 2021, 09:23:04 PM
TOB
It was not unusual for the snorkel to be a slightly different shade compared to the ram air base.
TOBKOB
The paint between the snorkel and base was the same shade and very good condition and that is where I matched the color. My air cleaner base and snorkel seemed to me to be a match, at least not a noticeable difference. Some may vary but I don't think mine did. :)
TOB
