VERY Original '67 GT500 on BaT
Started by 2112, January 26, 2021, 10:54:49 AM
Can someone post a pic of the  reinforced beehives/upper shock brackets(reinforced front upper shock mounts) that are mentioned in this thread? Thanks. Gary
Quote from: shelbydoug on January 28, 2021, 04:58:28 PM
here ya go
     Does your example have "Heli-Coil" inserts installed; and if so, then were the washer additions threaded originally?      ???
Quote from: pbf777 on January 28, 2021, 05:46:14 PM
here ya go
Scott ,original reinforced brackets simply had washers welded on to unmodified Mustang brackets.There was no other modification with the threads.
rhjanes
Quote from: Chad on January 27, 2021, 04:55:23 PM
Quote from: shelbydoug on January 26, 2021, 03:31:15 PM
There are some really good detailing pics.
Sounds pretty good when you run it but I wonder if it starts right up like that hot in those 100 degree summer days?
I do not know about everyone else but I do not drive my car when it is 100 degrees outside! ;D
You must not be in Texas, Arizona....  ;D
here ya go
Yes that one is heli-coiled to use with 3/8" bolts for competition use. The flat washers are not normally threaded but those are the 67 beehive.
The '68 I have as smaller diameter (OD) washers. The 67s are larger.
      Thank you both.     :)
Quote from: shelbydoug on January 28, 2021, 06:54:48 PM
here ya go
67-70 reinforced upper brackets typically all the same size washer. You should not be able to tell from construction from one year to the other.
68krrrr
Great detailed pics for sure ,something i noticed that i haven't seen before is the sideways radiator tag ,was this a Friday afternoon thing or pretty common ?
Current
1967 GT500 #1724
Nightmist Blue /Parchment
2005 Ford Gt Midnight blue
1934 Ford Chopped & channeled
Previously owned
1968 GT/CS
"Fly low & avoid the radar"
Thanks Adam
Quote from: 68krrrr on January 29, 2021, 01:59:06 AM
Not typical IME
May have been apart and cleaned or rodded at some point for maintenance purposes but can't be certain about that given the pictures
Yes plenty of nice clear pictures but of course what we would expect on car with its history, write up and seller :)
Is it typical to have the bottom of the transmission stamped like that?
I'd love to know the date code on that bell? Did I miss that pic Vern? Maybe I got blurry eyed?
QuoteIs it typical to have the bottom of the transmission stamped like that?
Very typical
here ya go
Thanks, I figured that was it as I have those on my 70 and also on my old 68. I went looking at the some other 67 Shelbys on BaT and they all seemed by the pics to have the non washer variety so it made me question if I was looking at what many were saying here.  Gary
     Maybe I'm just not seeing it correctly but what are the numbers stamped into the top of the shock tower?      ???
Quote from: pbf777 on January 29, 2021, 03:57:52 PM
Export car. Had to be stamped by law I was told . Also this plate was installed. Gary
