WTB: 67' Shelby Parts...
Started by FordGT, January 29, 2021, 10:16:24 PM
FordGT
Looking for the 67' Passenger side grille mounting bracket....    Does anyone repop this bracket?
Quarter panel fiberglass end caps
C7ZE HIPO head date coded around Dec,1966
1 - early aluminum tail light trim, without screw holes
Quote from: FordGT on January 29, 2021, 10:16:24 PM
Could you clarify more what part you are talking about - 67' Passenger side grille mounting bracket....  .   I don't know if I have this part because I am not sure what you are referring to.
Are you looking for the Shelby specific hood pin support and upper, outboard grille attachment extension bracket of which the passenger (right side) has the kink in it - like this?
FordGT
Sorry I do not have one to sell . The good news is Branda sells repros of the part . http://www.cobranda.com/19shhopinbr.html  . It is not a complicated part to make consequently the repros are very close to original in appearance. Originals are few and far between so you will have to beat the odds to find one plus the repros have been out for so many decades that it is very likely any used one you find will be a repro then a original. I would suggest buying the repro rather then waiting to try and find a original and then replace it if and when you find a original . If you buy the repro which is only sold as a pair you will be able to compare the differences to the one original that you have. The differences are nuance in nature so don't expect anything dramatic.
tater_51
Are you looking for a single 67 hipo head?  Disregard, I see your looking for a non-smog head, this is dated 6M22 and is a plugged thermactor head.
