New Owner - 67 GT350 #2645
Started by Britton, January 30, 2021, 12:29:57 PM
Thanks for letting me take it for a spirited drive around the block!
Plenty of good memories to come!
Jon
Side-Oilers
Looks "bitchin"...as we used to say.  I love the Torq-Thrust look.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
Quote from: Side-Oilers on February 06, 2021, 09:36:07 PM
+1
mark p
+3
Love the man-tires. What sizes? 15x7" in back?
Britton
Thanks for the compliments. I keep making excuses to go out to the garage. :D Wheels are 15x7 AR Torq Thrusts with 225/60/15 all around. Once weather clears up, I'll get some better pictures.
1967 GT350 #2645
Quote from: Britton on February 06, 2021, 11:04:11 PM
Good choice on the driver wheels IMO.
Skidado
I notice in the picture of the engine bay of #2645 that the thermostat housing is not painted. Most pictures I've seen of 'restored' engine show the housing painted blue.
Is this another variation or running change in production?  What would you expect to see on #2751 from the factory?
Many thanks for any information you can share.
David.
Quote from: Skidado on February 21, 2021, 05:11:02 PM
David.
To the questions above...I don't think that is a running change, perhaps as a result of required maintenance and cleaning-up of existing parts at the same time.
Yes, painted blue is what would be expected based on known/believed practices.  The coil location would be another item that is not typical of assembly line practice.
Looks to be a very nice car!
Agree not a running change. may be due to maintenance or from the fact that paint didn't stick as well to aluminum as it did to steel. You will see the same on some old pictures of the timing cover and or the water pump on some examples
Housing, bypass hose, clamps and attaching hardware were reused when the intakes were change after run test. Would expect to see some damage to the paint from the removing and reinstallation steps
Hockeylife
Quote from: JD on February 21, 2021, 05:35:24 PM
David.
What is considered the typical coil location? Anything that would make it vary?
Quote from: Hockeylife on February 21, 2021, 09:07:59 PM
Did you happen to see these two threads a a start? They both are focused - or started out focused on Thermactor GT350's that were built in the spring or so of 67
https://www.saacforum.com/index.php?topic=13620.msg112919#msg112919
https://www.saacforum.com/index.php?topic=6246.15
Rest typically just like 65-6 GT350's and 289 Mustangs without Thermactor
Britton
JD and Jeff are correct that there are some engine related items that are not assemblyline correct due to prior owner maintenance. The coil type and mounting location, some hoses/clamps, etc have been replaced over the years.  The thermostat housing should be blue as indicated. I am actually in the process of addressing most of these items.
1967 GT350 #2645
Hi Britton.
Looking pretty good.  Please tell me what size tires you put on.  Same front and back?
Quote from: 6s1640 on February 22, 2021, 01:32:55 AM
Hi Britton.
Britton
Jr. Member
Re: New Owner - 67 GT350 #2645
« Reply #65 on: February 06, 2021, 11:04:11 PM »
Quote
