'65-67 Shelby/HiPo Engine Parts - UPDATED Again
Started by marvs289, April 04, 2018, 04:42:18 PM
marvs289
o Used Fans, A67, $600,  G4, $700
o Motorcraft Distributors, $350
o Rebuilt Original S2MS Carburetor, 755, $1250
o Timing Covers, $125
o NOS Intake Valves, $20/each, Exhaust Valves, $25/each
o NOS Valve Springs (6), $25/each
o NOS Rocker Arms with Fulcrums, $275
o NOS Valve Spring Retainers, $250
o NOS Early FoMoCo PCV Valve, THREADED, $80
o Used K-H Disc Brake Porportioning Valve, $150
o NOS BF-601 Spark Plugs, box of 10, $100
o Original '65-66 Firewall Heater Delete Plate, $75  Last one
o Original C5AF-10A352-H Alternator Pulley, $125
o RARE '67 TE Heads Set Castings, Tested, $1900
o RARE '67 Rebuilt Set Non-TE Heads, 6M8, $2400
o NOS S1MS Sway Bar, $250
o 66 W-MO, 10 65, Radiator Top Tank Only, $300
(Missing C4ZE G2 Tag- can be purchased)
o Early 289 Open Letters Cobra Valve Covers, $425SOLD
o Early 289 Cobra Street Oil Pan, $700 SOLD
o Used Block 3M30, $1200 SOLD
o Heads- 3H15 Set Castings,Tested, $1900
o C3 (1) Casting 4A14, $1000
o C8 Set Heads Non-TE 9K23, $1500
o C5 Distributors, Used $500, Rebuilt $625
o NOS Early C3 Timing Set, $425
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight, AND Thrust Plate)
o NOS Later C5 Timing Set, $325
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight)
o Aluminum Water Pumps, $400
o RARE Reman '65 Cast Iron Water Pumps, C5OE-B Repro Impeller $425
o Reman '66-67 Cast Iron Water Pumps, C6OE-A Repro Impeller $325
o NOS Autolite Bypass Hose, $40  only 2 left
o NOS Autolite NO Star Spark Plugs, BF-32, BF-42 $60 set
o NOS Piston Pins $80
o Used C5AE-A Crank Pulley, $40
o Used Rods, $500
o Used Rods with Used Std Pistons, $700
o NOS Boss 302 Rods, not numbered, $900
o NOS Std Pistons, $600
o Used Std Pistons, $400
o New Set Sealed Power 4.030" Pistons, $400
o NOS Oil Pump with Pickup, $150
o NOS HiPo/427 Autolite Dual Point Tune-Up Kit $150
(Includes (8) NO Star BF-32 Plugs, (2) DP-5 Points, (1) DC-5 Condenser)
o NOS Gaskets, Head $100
o NOS Set Rocker Arms with Fulcrums, $275
o NOS Set Push Rods, $80
Prices do not include shipping. I will combine shipping in the case of multiple purchases. Pictures upon request. Thank you
bhoulis
FordGT
What's the Ford stamped part number on the 67' fan?
marvs289
Sorry for the delay, pretty busy. 911960. It's a service replacement for 63-66 HiPo Fan. If you have a 67, you need a C6OE-D, standard 4 bladed fan. Thanks
Quote from: marvs289 on April 13, 2018, 01:58:33 PM
Correction C6AE-E marked for 67 hipo at least what came on 67 GT350.
