67 GT350 engine paper label
Started by Bob Gaines, February 05, 2021, 04:43:23 PM
Does anyone have a picture showing a original the engine paper label glued to the coil? The picture of #0050 is taken at the wrong angle so it can be seen in that one. Original only and not repro . I have a strong suspicion that the current repro that everyone uses for the 67 GT350 is wrong in printed content.
67411F--0100-ENG.
Quote from: Bob Gaines on February 05, 2021, 04:43:23 PM
Hello Bob,
I have another photo of 0050's engine bay taken from a different angle.  I have attached a cropped down portion of that photo that shows the coil and engine label.  Not sure if it includes everything that you are looking for.
Eric
Quote from: 67411F--0100-ENG. on February 05, 2021, 05:11:46 PM
Hello Bob,
Eric
Yes it does. Thank you.
The 245A on the 67 GT350 MT engine in the vintage photo of #0050 is different then the 245K repro label currently available ECS listed for 67 hipo MT.
Identified as from Travel & Traffic magazine Jan 1967.
From a non-Shelby standpoint the location of attachment changed during the production year
To add to the discussion. No wonder there can be confusion. e may also want to look at the aluminum tags also here or another thread
From the add/delete sheets I looked at
E-245-A - Listed as 289 4V HP with 4 speed no AC (Grp # 2571)
E-245-? - Rest is not viewable  (Grp # 2572)
   246-A01 - Listed as 289 4V HP with auto and no EECS (#Grp 2574)
E-245-B - Listed as 289 4V HP with 4 speed EECS engine (Grp #2596)
E-246-A - Listed as 289 4V HP with 4 speed EECS engine (Grp #2613)
Kevin Marti included in his Tagbook that he had Ford documents showing the following. The date of the information is not available at this time.
289 4V HP  with 4 speed         245-A01
289 4V HP  with automatic      246-A01
Was there a change in identification codes during the production year?
Guess there is a possibility
At least the Ford documentation does not agree with each other for some reason
DGSOH
Hello Bob,
Eric
Sorry, off topic but the bypass hose and clamp appear to be unpainted in the photo. I thought they were painted?
Is there a character preceding the 245? One of the reproduction labels is showing the assembly plant code.
I'm not seeing any hint of that on either the 500 or 350 labels?
Quote from: DGSOH on February 06, 2021, 04:29:30 AM
Hello Bob,
Eric
They are and it is although thin to me from the photo.
just playing around, so if these were on a 1 inch tall roll they might look something like this??
(Will post on the BB thread of the similar topic too)
Quote from: JD on February 06, 2021, 09:57:23 AM
Based on the vintage photos the "01" appears to be eliminated.
Quote from: Bob Gaines on February 06, 2021, 10:05:46 AM
and missing a letter character after the 245/246. with no space in between as in 245A .
The Label on -00100 appears to be Micro gamma Condensed. We can't see the 405 but there is what appears to be the tip of the 5 and the A is not spaced from it.
The A appears to be double spaced to the 01, so the 350 labels and 500 labels are not exactly the same layout.
I vote is was some type of an instant label maker rather then a roll of preprinted labels.
Quote from: shelbydoug on February 06, 2021, 10:27:28 AM
Possibly not the same since these were built and labeled at different location. Suppliers of the labels may have been different companies
Still believe in the roll. It matches some other sticker applications and makes shipping and carrying multiples easier
Quote from: Bob Gaines on February 06, 2021, 09:11:32 AM
Look painted to me when comparing the finish to the face of the water pump in the lower right
