Antifreeze in oil, HELP
Started by Corey Bowcutt, February 21, 2021, 11:12:39 AM
sg66
Quote from: Corey Bowcutt on June 25, 2021, 04:52:48 PM
I was informed that the main and rod bearings were very worn on one side as if the crank was not true so rebuilding is definitely a good thing.
I'm guessing your rod bearings wore out on the top side? If so, that's what I would expect mainly due to combustion and compression strokes having more pressure on that side and with anti-freeze in the oil, the wear would be accelerated. My other guess is the bottom of the mains are worn? Same idea just switch where the most pressure is applied. Sounds like you caught it in time which is always a good thing.
Sounds like a quality rebuild should take care of it.
Hopefully you have it back running before summer is over, then I smell a "road trip" in the future 😎
Corey Bowcutt
#63
Very much looking forward to road trip.
What is 331?
