Battery post rubber piece
Started by hertzz350, February 22, 2021, 07:20:37 AM
hertzz350
My car #6s689 has the rubber battery post protector attached with staples. I have noticed that some were attached with plastic pins. When was the change over? Did they start with the staples then switch to plastic pins, or the other way around?
current owner of 6s689
Previous owner of 6s1855 ,6s1297,6s731
greekz
6S1134 has 3 staples holding the pad.  The pad does have holes for pins.  An early February 1966 build at San Jose(a guess).
Greek
SFM 6S1134  '67 GT-350 #2339
6R07mi
Nov 1965 SJ build, staples over push pin holes
jim p
jk66gt350
6S1575 has the plastic pins only.  2nd or 3rd week of March 66 Ford production from what I have been able to determine.
At San Jose they started with staples then moved to the plastic "rivets" or plugs. Based on research the change over took place between 6R164xxx and 6R172xxx. Change over appears to be approx during Feb 1966. The use of the prepunched shields does not coincide exactly with the change over to the prepunched inner fender panels around the time of change over
This where using Mustang examples really increases the number of unrestored and unrepaired examples to better focus changes shared by them as well as Shelbys
Thread on the CMF related to the running change
http://www.concoursmustang.com/forum/index.php?topic=14988.30
Hope this helps
Doug C
988 has the staples, however, majority of the rubber is gone.  Just the staples are there with little pieces of rubber.  Any idea if this piece is being reproduced?  Thanks
jk66gt350
I noticed a repo version last time I was on the Virginia Classic Mustang site.  https://www.virginiaclassicmustang.com/66-BATTERY-POST-TO-FENDER-RUBBER-SHIELD-P1181.aspx  I assume other Mustang parts vendors may carry these as well.
Quote from: jk66gt350 on February 22, 2021, 08:59:33 PM
He may be looking for the early version without the holes. Looks like an easy piece to make if that is the one needed for the specific application
Britton
Quote from: J_Speegle on February 22, 2021, 03:47:40 PM
Hope this helps
If it's helpful, the 66 San Jose fastback I owned had the riveted rubber pad. VIN was 6R09K168XXX which falls right in the transition period.
1967 GT350 #2645
Quote from: Britton on February 22, 2021, 11:23:21 PM
Hope this helps
Most likely meant stapled and not riveted right?
Britton
Quote from: Bob Gaines on February 22, 2021, 11:28:33 PM
Hope this helps
It had the plastic rivets not staples.
1967 GT350 #2645
Thanks - very helpful since it is one that I didn't have and its the Ford VIN. Have two examples with higher sequential number than yours with staples  Had a fair number of the ones already posted in the study.
Just wish we had real build dates for the 65-66. Sure would make these surveys more exact like we can do for 67- up cars
Quote from: Britton on February 23, 2021, 01:16:44 AM
Hope this helps
Sorry ,I am used to hearing them referred to as plastic pins . When you said riveted that didn't correlate. Just different terminology .The added word "plastic" confirmed in my mind what you were talking about.  No worries.
 477 does not have a pad or holes there. Yes , original apron.
