Removing yellow cad off of bolts?
Started by shelbydoug, February 25, 2021, 09:36:24 AM
Since the yellow cad eventually washes off of it's silver zinc cad plating, is there a way of expediting that on new yellow cad bolts? Simply. This isn't NASA.
I'm guessing you're referring to gold dichromate on zinc plated parts?  If so, I've found that evaporust will remove it safely.  I've done this on several parts that I had re-plated and the gold didn't turn out good.  I have the yellow gold solution to dunk them in.
There are other quicker methods, like vinegar (if I remember right).  Or, quick acid dunks.
Quote from: CharlesTurner on February 25, 2021, 09:40:57 AM
Yep. "Evaporust"? What is that? A rust remover solvent?
Just did this on some bolts. Was too cheap to buy anything new (didn't have any evaporust handy) so raided the household cleaning shelf, found some toilet bowl cleaner called "Kaboom" used to remove scale & rust stains. It contains hydrochloric acid, made quick and easy work of the yellow zinc.
Evaporust is a  great product that car guys need and u can buy at local stores and reuse it when needed to clean car parts.
I just tried it. It washes the yellow off like it is watercolor paints! It doesn't even seem to leave a residue.
Now I know what I'll be doing all day. Thanks. Very helpful suggestions.  ;D
Quote from: shelbydoug on February 25, 2021, 09:47:10 AM
Find it in many places. I bought mine off of Amazon a few years ago. A bucket with a inner screen bucket. I just put rusty parts in it and let them sit.  BY no means am I supporting the seller in the link-just the first link that came up. I like the bucket method. I have also used the Jell on my 428CJ engine and headers.
https://www.walmart.com/ip/Evapo-Rust-The-Original-Super-Safe-Pail-Rust-Remover-Water-based-Non-Toxic-Biodegradable-3-5-Gallons/48810394?wmlspartner=wlpa&selectedSellerId=1330&&adid=22222222227037637421&wl0=&wl1=g&wl2=c&wl3=92176423577&wl4=aud-430887228898:pla-183842078177&wl5=9017001&wl6=&wl7=&wl8=&wl9=pla&wl10=100362769&wl11=online&wl12=48810394&veh=sem&gclid=Cj0KCQiAst2BBhDJARIsAGo2ldWDJ61vXUXqngQLBDWTg2rI-gzssxBwHge3sy1U1WVx9AfgHEnczOkaAtHVEALw_wcB
https://www.ebay.com/sch/i.html?_nkw=Evapo%20Rust%20Remover&norover=1&mkevt=1&mkrid=711-156598-766339-8&mkcid=2&keyword=evapo%20rust%20remover&crlp=435081408607_&MT_ID=590136&geo_id=10232&rlsatarget=aud-649939740364:kwd-300703209816&adpos=&device=c&mktype=&loc=9017001&poi=&abcId=1145996&cmpgn=8068618706&sitelnk=&adgroupid=78578601090&network=g&matchtype=e&gclid=Cj0KCQiAst2BBhDJARIsAGo2ldUHK9SG1TepL2GF1K5loNv5urH1dud7wwCXNBx98JcFPMd7cNn0r90aAtBSEALw_wcB
Quote from: shelbydoug on February 25, 2021, 10:18:38 AM
Tried what, Doug? "Kaboom"?
Can you elaborate your process and the solution you are using? Thanks. Gary
Quote from: shelbymann1970 on February 25, 2021, 10:22:36 AM
I had a little "jelly", grape I think, laying around. Tried it on one bolt. Worked great.
Went to Lowe's and bought some Rustoleum Rust remover Jelly in the squirt bottle. Works the same way. Tastes great, less filling.
Quote from: shelbymann1970 on February 25, 2021, 10:25:13 AM
The re-dipping?  I have the gold dichromate stuff, I think Caswell sells it.  Mix it with water per spec ratio and just dunk the parts for 30-60s.  Use a heat gun to dry as they come out.
This won't work very well on bare metal parts.  A shiny silver zinc base is required to get the best results.
rockhouse66
I do same as Charles.  The thing about Evaporust on these parts is it will actually brighten the zinc as a side benefit of removing the dichromate.
Quote from: rockhouse66 on February 25, 2021, 06:22:20 PM
I didn't use Evaporust but they did come out pretty shiny.
Have used vinegar to remove the dichromate in the past. If full strength have to watch it as it can go too far and start removing the base zinc coat if you leave to too long
