Rocker Molding Removal
Started by Corey Bowcutt, March 12, 2021, 06:40:59 PM
Corey Bowcutt
Can anyone tell me how to remove the rocker molding on my 68 GT350?
Corey
JWH
On the back side of the lower fender where my thumb is located, you should find a nut that must be removed. After that, place the palm of your hand on the top ledge of the molding and while pushing down, curl your fingers under the lower edge of the molding and pull out. Work your way from one end of the molding to the other pushing down and pulling out to detach the molding from the five or six plastic clips that hold it in place.
Quote from: Corey Bowcutt on March 12, 2021, 06:40:59 PM
Corey
if they are installed correctly there is a nut behind front fender splash shield /  i just  start at front and  push down on top  to un hook bottom and work my way back /  once the front clips are loose you can  kinda twist the rocker  from front and  work each clip loose
Corey Bowcutt
