wanted original 1969 mustang upper control arm
Started by musclecarman15, March 15, 2021, 03:55:08 PM
musclecarman15
wanted original used 69 mustang upper control arm....need a good used one with riveted in joint and untorn boot...need a nice clean one....68 or 69 is the same...thx keith 318-393-1502
Quote from: musclecarman15 on March 15, 2021, 03:55:08 PM
Keith depending on the time frame some uppers had the cut back for tire clearance and others didn't . It is probably best to clarify which that you need. Marcus did a good write up on the subject .http://anghelrestorations.com/uploads/3/5/1/2/35122002/65_to_73_suspension_guide_v2.4aopt.pdf . Skip to page 14 for the cut back ,non cutback details.Best of luck on your search.
musclecarman15
Sorry ,thought about that afterward...would like non cutback version....thx bob appreciate the tip
i have some but finding one without damaged grease boot is hard to find as most are damaged when removed from spindle.
I got 10 or so rust free from southwest trips but everyone has a crack in grease boot from too much grease  or  tore when removed like most of them are  and i can send it out and have a nos grease boot installed if u dont find one ok
musclecarman15
ED,first ,thank you...i have my original  very nice upper arms (have bolt in joints)....was just trying to find a complete original (untorn boot 68-69 non cutback), as i have one...if i cant ill just have original joints reriveted in with nos boots....thx keith
