Headlight Bucket Wiring removal
Started by Corey Bowcutt, March 19, 2021, 09:51:10 AM
Corey Bowcutt
I need to remove the cable harness from the headlight buckets.  Connectors on both ends of the harness are too large for the hole in the bucket.  I assume one has to remove the wire/contacts from the connector on the headlight side of the harness.  Just wondering if there is a trick to doing this so I do not damage things?
Thank you,
Corey
Of course. There is a notch on the side of the connector. If you put a small probe in there it will release the wires from the hard plastic plug
Corey Bowcutt
shlb69
Where is best place to do it as I have 2 that won't release.
Here is a blue point wire terminal removal tool that i use . NPD and many others sell equivalents. You can get a idea what the release probes look like if you want to fabricate your own.
