Brake drums on 65
Started by DRGT350, March 24, 2021, 11:04:29 PM
DRGT350
Gentlemen- were the rear stump painted black? Or natural with the Cragars?
The picture is my drums after restored with no paint -
Thanks !
DRGT350
Would it be a flat, semi gloss or gloss black?
Quote from: DRGT350 on March 24, 2021, 11:37:19 PM
Semi gloss typically .
DRGT350
Thank you Bob and Charles -
TO add - normally just the face  with a large brush , except for what every drips and drabs made their way onto the other side surfaces during the sloppy application
DRGT350
ok - thanks Jeff  - appreciate all the help !
DRGT350
Quote from: DRGT350 on March 26, 2021, 07:18:56 PM
Jeff-  like this ?
Given that the wheels will likely be mounted that will likely do. If you do it again you might want to wait for them to be mounted on the rearend as originals appear to show that the brush did not pass over the holes where the studs stick through suggesting that that they were mounted.  On some runs are visible traveling down the face as if they were mounted also.
DRGT350
Ok-  thanks Jeff-,
I'll clean up a bit around the holes..
Appreciate the help !
