WTB: 1969 Shelby Part and Literature
Started by nightmist67, March 31, 2021, 01:12:05 PM
nightmist67
Looking for a 1969 Shelby factory assembly line firewall insulation pad and owner's warranty card.
Quote from: nightmist67 on March 31, 2021, 01:12:05 PM
If the warranty card is meant to go into your car you may want to check with Kevin Marti to see if he reproduces them. They have the vin on them and consequently would not be correct unless the vin matched the car it is placed in. For example it would be subject to deductions in a concours venue if the difference was noticed.That may not matter to you but wanted to make you aware in case it does. You also may want to clarify if the firewall pad you need is for a ac equipped or not. You can always cut out material for a AC application  from a non A/C pad but it is harder to patch material back in for a non AC application on a A/C pad. Best of luck with your search.
nightmist67
Firewall insulation pad from an A/C or non-A/C car is acceptable since application is for an A/C car.
