Long racing lug nuts
Started by Speed Six, April 13, 2021, 09:23:29 AM
Anti-seize is your friend.
Stainless is ok if you roll the threads and don't cut them.
In my experience on a regular bolt/nut application I always find 2 to 3 out of a hundred stainless bolts will strip out.
How fast are you going to require aluminum lugs?
Quote from: shelbydoug on October 09, 2021, 04:30:52 PM
     It had more to do with the intended applications; that being of generally light weight little European sports cars, most often with not so powerful little four cylinder engines, this where just a little difference just 'might' be noticeable.      ::)
