Grill Emblem for 1965 GT 350
Started by DRGT350, April 16, 2021, 01:00:09 PM
DRGT350
Gentlemen -
Is there a proper or "correct" hardware to attach the grill emblem on a 65 GT 350?  Any pictures would be helpful also !
Thank you,
Check with Brant at VA Mustang.  They list the 66 clips on their website.  65 uses the small push-on's without the other larger pieces.
https://www.virginiaclassicmustang.com/66-GT-350-GRILL-EMBLEM-CLIP-SET-P1988.aspx
texas swede
Dave, On my car 5S275, the grill emblem is held by small push on clips and round washers.
Texas Swede
DRGT350
mygt350
Bo, would love to see picture of the washers on your front emblem.
texas swede
Hi Martin,
Took a picture today but it didn't come out that good but if you increase the size
you can se it.
Texas Swede
pmustang
I can tell you the Scott drake ones come with push on clips that are too large and don't work
Here is Texas Swede's image with some adjustment to hopefully make it easier to see the washers and push-on "speed clips"...
mygt350
Perfect Bo and JD. Unknowing might attach horse to grill without the washers.....Guess how I know....
mygt350
If you order the Scott Drake kit from Virginia Classic, it comes with 3 press on nuts, horse has 4 prongs ....
mygt350
Were the original washers painted or coated in any manner?
texas swede
Mine are cadmium planted as far as I can tell. As regards the clips, it has to be understood
that original emblems C4 marked has much thinner pins than the replacements C8 marked.
The one on my car is C4.
Texas Swede
Quote from: mygt350 on April 17, 2021, 10:46:38 AM
When used on the 66 grille only 3 of the pins (upper, and 2 side pins) are used. IIRC there are some interference issues with the bottom pin. For a while I used a C8 service replacement and had to cut the lower pin off since they are thicker as Bo mentions. Now using an original C4 emblem which fits without removing the lower pin but it's still close, right next to the grille bar...
mygt350
The 3 brackets in the Virginia kit are not used on a 65 honeycomb grill. Just the flat retaining nuts. Kit has 3 small flat nuts and the small pin horse has 4 prongs.
mygt350
Would like to get couple owners of real 65 GT350 to see if they can take look at the washers on the grille running horse and let me know what the washers are coated with and the outside diameter of the washers.
