Speedometer cable Details
Started by Corey Bowcutt, April 16, 2021, 02:11:32 PM
Corey Bowcutt
I bought a new speedometer cable and I have a few questions.  The new cable has a 4-5 inch long reinforcement tube (shown in the picture) that came with it.  Does anyone know where this piece should reside in the routing of the cable?
Also the clamp shown in the picture was used on my original cable.  This is the clamp used down by the transmission support.  Does this clamp look correct?
Thank you,
Corey
Auto or 4 speed as they are different.
Corey Bowcutt
67350#1242
The reinforcement protects cable as it passes through transmission support.  I have not seen that type clamp used but am more familiar with 67's where a clip type was seen on passenger floorboard.  Original 4 speed cable has a metal band around cable where it passes through the clip.
68blk500c
Agree -that clip is incorrect.  It can be a hard piece to find.  Posted a pic on here previously; will have to look for it, again.
At least your cable is black.
If this helps, here is what I have for the '67 Version in the passengers side floor area...
68blk500c
Cory:  Finally found pics of original '68 auto tranny cable clip.
Hard clip to find unbroken  and i gave one to eddie r to make last fall  as its a much needed part not serviced by ford.
