1969 re-assembly
Started by corbins, April 22, 2021, 07:04:35 PM
corbins
I'm helping a friend reassemble a 69 FB . It was purchased painted and rolling  with a bunch of boxes of parts.
I see a hole in each outer wheelhouse .... brake cooling ducts?
Also  found 2 pieces - fiberglass with similar holes in them ... related to above ?
He may have to buy assembly manuals.. Shelby specific
One more... wat type of rivets for vin tag on dash and Shelby plate on apron .. steel ?
Thanks for any help !
Steve
Quote from: corbins on April 22, 2021, 07:04:35 PM
Possibly depending on the hole size. If for the brake ducting then there will be screw holes near the larger hole also
Quote from: corbins on April 22, 2021, 07:04:35 PMAlso  found 2 pieces - fiberglass with similar holes in them ... related to above ?
Can't be certain with out a picture. For the holes mentioned above there is a flexible hose and a metal ring that gets inserted into the end of the hose and helps hold the end to the wheel house
No "Shelby Plate" used in the engine compartment. Sure the Mustang and Shelby assembly manuals will be of great help though the can have some details not applied to real cars
aj
Photo from rear wheel well
aj
Photo from inside quarter panel showing air plenum behind the 69/70 side scoop.  Routes into rear brake duct component
aj
Photo of flat metal ring that supplements/secures rubber ducting to hole in wheel well
aj
Photo of air plenum that is located behind 69/70 shelby side scoops (inside quarter panels).
corbins
Jeff, AJ, thanks very much !!  Very helpful. Now I'm trying to figure out the front fender rear splash shields. I dont see any mounting holes at firewall pinchweld where one would normally see the three holes for the mounting screws ??
Quote from: corbins on April 26, 2021, 09:04:13 PM
Don't know what has been done or replaced on your particular car. Originally the two facing inward were often covered (the hole and threads) when looking at the area from the outside of the car with the shields removed.  But sure you have looked up and down and on both sides already
corbins
Quote from: J_Speegle on April 26, 2021, 09:20:55 PM
Thanks Jeff , will double check, but so far I see no signs of any fender rear splash shields ever being installed. Unless whoever did the body/paint work decided to weld em up for some reason. Appreciate the respose !
For those following along or reading this series of posts later
