Correct Solenoid?
Started by Jbarela, April 26, 2021, 01:21:12 AM
Jbarela
Hey there all, need some help and pics I guess are always nice. I need a solenoid for our car but I dont have any reference as to what was original to even start looking for one. An eyesore in the engine compartment I want to fix. Thanks!
GT350Lad
Hi, what year and number range car are you working on?
Helps us to guide you
Cheers
6S373
6S1276
Jbarela
outlawincorporated
Image attached
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
mgreene
I may have an extra one of these if you need one.
'66 GT-350H
'69 428SCJ Mach 1
'72 Pantera
Jbarela
Quote from: outlawincorporated on April 26, 2021, 02:28:57 AM
Image attached
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
thanks for the pic phil! Is that assymbly line or service replacement.
Jbarela
Quote from: mgreene on April 26, 2021, 09:01:33 AM
yes please check and see what you have. Would like an NOS one and not used.
mgreene
Quote from: Jbarela on April 26, 2021, 10:57:34 AM
Sorry, no NOS ones, they would all be used.
'66 GT-350H
'69 428SCJ Mach 1
'72 Pantera
Karguy
Have you checked with Virginia classic mustang? They have reproductions that appear to be virtually perfect.
Quote from: Karguy on April 26, 2021, 11:28:47 AM
They are nice, but the hardware is all wrong... the copper lugs should have fine thread and all the nuts should have captured tooth washers... there was also gray sealer used at the base of all 4 nuts.
S7MS427
I bought some reproductions a couple of years back and they were junk.  They would hang in the engaged position and the starter would not disengage.  I think they were from Marti Autoworks.  I finally sent them back and got my money back.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Quote from: S7MS427 on April 26, 2021, 11:48:55 AM
From what I understand, the new ones on the market are made by Alloy Metal, the ones that do a bunch of repro wiring.  I have no first-hand experience with them, but supposedly they don't have the issues with the former versions.  Too bad they couldn't get the hardware correct.
I had a nice original like the one in Phill's photo restored by David Davis at DSD Restorations, turned out very nice.
https://www.dsdrestoration.com/about
Jbarela
Quote from: s2ms on April 26, 2021, 12:27:16 PM
was it rebuilt internally or just physically restored?
Both. Internals were shot, engine would keep running when the key was turned off. He replaced the internals, restored the exterior, and used the correct gray sealer Charles mentioned on the bolts. Also used gyptal on the top rivet.
