1966 GT350 289 HIPO ENGINE NEW PRICE
Started by 429scott, April 12, 2018, 06:18:03 PM
429scott
I have a 1966 289 engine assembly from a 66 GT350, vin numbers have been verified by Mr Pardee. Engine has approx 10K miles(my guess), no lip in any cylinders all bores mic to 4.001-4.002, can easily be honed to 4.003 to fit forged pistons. Engine is apart, heads are complete.
289 Engine includes:
-crank hipo
-heads dated 5k2 5h20 one cast 20 other 21 both have 4V cast below exhaust port
-block dated 5k29 assembly 5l1w
-balancer not sure of date
-8 rods and orig pistons still assembled(note currently missing 1 rod cap I cannot find, will get replacement hipo rod if need be)
-cam, lifters, pushrods, most all bolts
-oil pump with pick up for t-pan
-dizzy rebuilt/restored by Mike Ulrey 2004 dated 5h
-timing cover(not original to engine)
-c6 cast water pump(not original to engine)
-hatchet weight
-COBRA T-pan S1MS
-COBRA intake correct early style no corrosion or damage S2MS
-1 set BB valve covers(not original to engine)
-rebuilt/restored 4201 fuel pump not sure of date
-water pump and crank pulley
-alternator brackets
this is a real deal engine I am not selling bs, I have spent 15 years collecting almost enough parts to build a 65 GT350 clone from nos original parts but my project has gone in another direction. I really think it would be a shame to split up the core of the engine as it came from one special car. I have noted all the parts that did not come from the donor GT350 engine, I collected these separately . Asking $8,500 or best offer. Can provide most any pics on request.
thanks Scott, I can be reached at 6107601576, parts are located in LV area of NE Pa. zip 18067
6s1139
Quote from: 429scott on April 12, 2018, 06:18:03 PM
Are you able to share the Shelby VIN on the block?
KR500
Quote from: 6s1139 on April 12, 2018, 07:52:03 PM
Not sure if you are asking for the VIN on the block? That is the Ford VIN, no Shelby VIN on the block and the Ford VIN should not be shared. If you are asking for the Shelby VIN that matches the Ford VIN to this block that would probably be alright.
Series inquiries please use the PM system
HOW TO IDENTIFY A FORUM TROLL
