69 eye brow moldings
Started by Gregory177, May 02, 2021, 05:03:08 PM
Gregory177
I am hoping someone can help me identify if I have two after market set of moldings or if one of the set is possibly original. Thank you in advance for any help. Also one set has spot weld dimples one does not.
Quote from: Gregory177 on May 02, 2021, 05:03:08 PM
I have not ever seen or heard tell of the repro eyebrow moldings with the spot weld dimples. I have seen original moldings that had very minor almost undetectable evidence of the spot welds and also re chromed original versions where the detail was virtually polished out .
Gregory177
Thank you for your response Bob. one set has brackets soldered in and one set tacked in.They both came in a box in trunk of car. The box they were in indicated they came from Branda in 07/08. Just trying to figure out the best most accurate set tu use.
The dimpled spot weld is what was installed at aosmith and early autolite boxed nos but the replacements never had the spot weld dimples and looked better so it depends on if u wants to be concours correct or the better looking replacements as both were made by the original vendor.
