Early Hood's Undersides Painted White or Black?
Started by NC TRACKRAT, May 10, 2021, 05:52:15 PM
Quote from: CharlesTurner on May 14, 2021, 04:24:58 PM
Quote from: Szabo on May 14, 2021, 03:30:56 PM
Here is a Pic from the Peterson Archiv,
it shows the early (first 14ten) GT350 Production in
the Carter Avenue Building, befor moving to LAX
Hope it helps a little bit
Greets from Germany
It's a good reference, but hard to know exactly in black/white photo if that is gray primer or white paint.  Regardless, we know that the white bottoms are something that was in practice after the move to LAX.
Most likely a primer prior to painting IMO because it is so flat in sheen. You can see a higher level of sheen in B/W photos of finished white bottom hoods.
chris NOS
i agree , and i don't think  a fresh-painted hood would be hold  on the ground like this ....
davez
Also looks like there is writing in marker at each hinge area as well as passenger front corner.
