Points wicks/felts
Started by shelbydoug, May 11, 2021, 09:46:53 AM
Where can I get some of the fabric felt wicks that are on the points rubbing blocks? The wick that is supposed to be under the rotor at the top of the shaft also?
I stole some off of a couple of old Accell points I had but I need to find another source of new ones?
Anyone know a part number and a source for them?
True, but that doesn't answer the question now does it? :D
I think it does - they are for sale. All you need is to buy them.
Quote from: shelbydoug on May 11, 2021, 12:18:14 PM
Quote from: Royce Peterson on May 11, 2021, 12:39:33 PM
...and the wick for the distributor shaft, under the rotor?
Here's one source for the oiling pad: https://www.ebay.com/itm/380936991984
There's got to be others.
Kind of pricey for a felt plug.
Yes, a bit of an elusive sucker too.
Found 2 part numbers in the 60-68, and 65-72 MPC's; FEK-12133-A and D0RY-12133-A, but doesn't look like it was ever available separately from Ford.
Strange that such a simple part is so elusive?
rhjanes
"Back in the day" a set of points cost was $1.  I'm thinking the points "Felt" was never serviced.  Just grab a $1 part and put them on.
mr68shelby
Is the felt for the distributor shaft wick under the rotor anything special? In the past I have gone to the fabric store and bought felt and cut a piece for the shaft.
rockhouse66
I have only seen that points felt for the cam on the Blue Streak points sets.  I think there is a little paper in the box that mentions the felt being impregnated with something and not needing any additional lube.  There is a Blue Streak grease for the points cam, called Lubri-Cam.
    I will check my NOS parts stash . I "may" still have a pair of "point felts" in a Ford package. Yes at "one time" they were serviced. Be patient and I will look.
Vcode
Felt - Distributor Cam Lubricator C3TZ-12A055-A
Quote from: Vcode on May 13, 2021, 01:01:08 PM
https://www.newhollandrochester.com/shop/c3tf12a055a/
Out of stock. Figures? $.42 each. Doesn't say if it has a Ford, Shelby or Cobra logo though? 8)
