LED Tail lights
Started by Grouper Trooper, May 28, 2021, 12:49:24 AM
Grouper Trooper
Is there any latest and greatest way to install LED 1157's on the 68? On my 69 cougar it was simply the bulbs and an electronic flasher.
Jayson Horadam
1968 GT 350 #1516
2 X 4 Holley's sittin' on all SCAT 331
www.mpaenforcement.com
PrettyMuchAShelbyGuy
Call and ask to speak with Vic. He's your guy. Tell him Tom Hughes sent you
http://www.thuntek.net/cougars_unlimited/
Tom - DFW, Texas
Cobrask8
Should be a bulb for Bulb replacement.
Upgrade the flasher to a slower one, such as the ones sold, or try an EL-12 relay style flasher
Quote from: PrettyMuchAShelbyGuy on May 28, 2021, 01:47:10 AM
I bought one of their first sets when they became available for my 70 Shelby. They are still working great. Gary
Grouper Trooper
I can't believe I thought this was such a big deal... been sitting on this project for over a year.
Just installed the 1157 LED's (already installed electronic flashers a while ago) and wow, "Let there be light"
Everything works but the turn signal lights dim out as it goes from center to outer, but it had started doing that before the bulb swap... will call Vic at Cougars Unlimited this week.
Thanks for all the advise!
Jayson Horadam
1968 GT 350 #1516
Cobrask8
Just need a flashed that holds longer, or a quicker sequencer.
Grouper Trooper
Roger Wilco, I will get back to this next week with a flasher change.
Jayson Horadam
1968 GT 350 #1516
Grouper Trooper
I'm such a doof. I had installed electronic flashers a few years ago. The only thing I needed for this to work was a fully charged battery and or the the car running! As stated by others, just a simple bulb swap with the electronic flashers!
Jayson Horadam
1968 GT 350 #1516
Cobrask8
GT - You did just identify a very common error made with 68-70's - Voltage. To properly test, the car needs to be either running or on a battery charger. Otherwise, it will be slow and dim.
Now have some fun and drive!
Dan
