1968 interior trim f/b
Started by Grouper Trooper, June 15, 2021, 05:30:41 PM
Grouper Trooper
I just need the corner trim pieces, left and right, that covers the seam between upper and lower panels in the rear under the glass.
Thanks!
Jayson
Jayson Horadam
1968 GT 350 #1516
2 X 4 Holley's sittin' on all SCAT 331
www.mpaenforcement.com
Tired Sheep
Pretty sure trim above your tear door should have screws
And the screws do not have beauty rings around them like the one in the forward piece. That is unless the hole is wallowed out requiring that to be done.
Grouper Trooper
Quote from: Tired Sheep on June 15, 2021, 05:33:18 PM
Hi, thanks
Trim above rear door has studs to the trunk side. Is that what you mean?
Jayson Horadam
1968 GT 350 #1516
Grouper Trooper
Quote from: Grouper Trooper on June 15, 2021, 10:25:23 PM
Hi, thanks
Hi Bob, thanks for the input. Yes, those screws are in for a mock up to see how everything fits. Panels and surviving trim are original pieces and not in the best of shape. AMK screws are here and ready for final!
Jayson Horadam
1968 GT 350 #1516
Tired Sheep
Yes trim strip on top of trap door should be held on by screws not studs
