Clutch Pedal Support ?
Started by oldcanuck, June 17, 2021, 10:22:55 AM
oldcanuck
All great information guys.... thank you.
One more question..... Does the clutch itself incur any extra wear if the pedal is not returning that last little bit ?
Bob
Knoxvegas, TN
Quote from: oldcanuck on June 18, 2021, 07:49:58 AM
Not the clutch but the syncros in the transmission likely are. Of course there is a bit of overtravel designed into the pedal linkage.
sg66
The throw out bearing is more likely to wear depending on how much "not returning" is happening
gt350bp
If you change the pedal bracket bushing to the roller bushings and weld the washers to the bracket correctly, the pedal should return all the way. If it doesn't, then I would guess the horseshoe bushings for the return spring are trash or the metal on the clutch pedal or the spring bracket has yielded. I had the clutch pedal on my 65 yield and all that was needed to fix was to weld and file the u-shape back into the pedal. I also just recently put the NPD clutch pedal stop in my car and now the clutch and brake pedal are about the same height. This was another nice part that was more than satisfied with if you are intending to drive your car. It is not an exact replacement, but nice for a good driver.
Don
gt350bp
+1 totally agree.
Quote from: sg66 on June 18, 2021, 11:59:54 AM
gjz30075
The Mustangsteve kit has sealed bearings and requires some welding and is heavy duty.
https://mustangsteve.com/product/bbk/
Greg Z
6S2249
oldcanuck
I went ahead and just ordered a standard rebuild kit comprising of 13 parts that all may or may not be used during the rebuild.
If the original stuff lasted 55 years, I'll let the next owner worry about it in 2075 !
Bob
Knoxvegas, TN
