Need help rebuilding GT350 engine
Started by avogodro, June 20, 2021, 09:07:42 PM
1. I would replace any stock pistons with a quality forged piston, new pins and plasma moly ring set. Call these folks and tell them what you want for a finished product. Are you planning to use pump gas? If so you will want to lower compression to less than 10:1. You don't want to use race gas all the time do you? Stock compression is too high for pump gas. http://www.raceeng.com/
2. No paint. BARE ALUMINUM!!!!!!!!
3. Gloss black. Any good brand will do. PPG, Sikkens, Akzo Nobel - you use what your normally would.
Quote from: avogodro on October 15, 2021, 09:55:04 AM
A few more questions regarding the motor rebuild
1. Can anyone give me a good source piston rings and possibly a new piston as replacement for the original? Trying to avoid chinese parts.
2. How can I prep the valve covers?  Should they be bare aluminum or painted/prepped somehow?
3. Is there a specific color black to paint the block?
Thanks Again for all the help.
Cant wait to get this car going.
S7MS427
Quote from: Royce Peterson on October 16, 2021, 10:43:23 AM
Right, bare aluminum assuming that these are the sand cast "open letter" covers.  Which they should be as you have a '65.  The so call "solid letter" die-cast covers were painted "wrinkle" black which is typical of the covers from the change over in 1966 and through the end of production in 1969.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
TA Coupe
When it comes to pistons talk to the piston Guru,  Randy AKA gt350hr as he has been in the piston business for many years.
       Roy
If it starts it's streetable.
Overkill is just enough.
  Thanks Roy , I have sent a PM to the OP and will help him out. 30+ years in the custom piston piston industry pays off sometimes.
