65 HiPo timing cover and water pump bolts
Started by mygt350, June 21, 2021, 05:44:49 PM
mygt350
I have a 65 Hipo engine in the shop with a hodge podge of bolts on the timing cover to block and water pump to cover. Need to find a really good set of original bolts with correct shoulders and markings for a early 65 Hipo engine with the thick timing chain cover. Don't know what owner was thinking but what's there is simply incorrect.
Please PM or send me an e-mail with pics and bolt lengths. I need all the bolts for the water pump and timing cover. Cant use damaged heads or pitted bolts. Picky, but owner is anal.
brandosaac
I have a few timing chain covers.
do you have a date code preference?
are you looking for the super early style ft cover where the water pump impeller actually sits inside the front cover
mygt350
Think I have located correct timing cover. But, still need correct bolts for the cover and the bolts for the alum pump for a early hipo engine.
