fuel line bead
Started by vtgt500, July 20, 2021, 04:51:41 PM
vtgt500
I'm faced with fabricating a a 3/8 stainless fuel line.  Line to hose connections require the steel line to have a retaining bead.  Simple bead forming tools are offered for aluminum lines, but anything advertised that's suitable for steel is impractical for making a single line.  Any experience with alternate bead techniques?
https://www.aircraftspruce.com/catalog/topages/parkerbead.php
Corey Bowcutt
I can tell you I bought the tool suggested and made a bead in a stainless tube and it worked great.
Corey Bowcutt
If you want to send me the line I will do it for you and return it.  You just pay shipping.  If you know how long you want it I probably have some stainless tubing I could use so you only pay shipping one direction.  I am on vacation but can check what I have when I return on Sunday.
Corey
Corey Bowcutt
This is a picture of the bead I did for my carb spacer PCV valve port.
Corey
If using the later thin spacer with the angled PCV outlet, cutting it down so it's straight and beading the end is a perfect substitute for a '68.
vtgt500
Quote from: Corey Bowcutt on July 21, 2021, 08:18:48 AM
Corey
That's a very generous offer I may take you up on.  Need to get everything in place, bend line and see what I've got.
