Clutch pedal height
Started by gt350bp, July 22, 2021, 03:49:43 PM
gt350bp
Making final adjustments today and was wondering if an approximate 2" difference in height from the brake pedal to clutch pedal is common for a KR? My brake pedal is about 6" from the floorboard to the pedal and that seems to be within specification. Just not sure of the clutch pedal height. Looked at old magazine and photos on-line and it appears that there is an offset. Any input is appreciated.
Thank you.
Don
gt350bp
Side-Oilers
Is your clutch pedal higher or lower than the brake pedal?
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
The clutch pedal is normally higher then the brake pedal, however, that is with the stock clutch.
It will ride lower (almost even) if you change to a diaphragm clutch.
gt350bp
Clutch pedal height is 2" higher than brake pedal. Using a RAM long style clutch with Lakewood bellhousing.
Yes, somewhere in that difference. Keep in mind also that the original brake master cylinder was a little wonky to begin with and if you reference the height of the pedal there is no set number.
The standard procedure to bleed the thing was that if you could put your foot under the pedal and still stop, you were ok and adjusted correctly.
Mechanics were refering to it as stomping the marshmallow.
A current replacement will give you a higher pedal and travel less to stop the car.
That reduces the contrast between the two but somewhere in the 1-1/2" to 2" difference is about right.
Makesure the bushings the shaft rides on are good. The original plastic ones would wear through and into the support wearing an oval shape into it.
If you haven't already done it, put the roller bearing "bushing" kit in it.
If you are worn there, that will also affect the static height of the pedal.
gt350bp
Doug,
68 shop manual indicates 6.20" brake pedal to floor sheet metal with 1.85" pedal travel. I think my brake pedal height is OK, but the clutch pedal seems a tad high. All bushings and clutch parts are new / restored. I'm thinking maybe the Lakewood housing pivot location might be causing the higher pedal height?
Quote from: gt350bp on July 22, 2021, 09:08:38 PM
Doug,
It's up to you but I think you are trying to fix something that doesn't need fixing?
Why aren't you using the Ford pivot bracket?
gt350bp
Doug,
Using Ford z-bar and pivots, (all restored with new bushings and felts) but I believe the Lakewood release arm bracket may be in a slightly different position than a on a Ford bellhousing?
Clutch pedal is typically 2" +/- higher than  brake pedal
gt350bp
Tim, thanks for the reply.
I checked and double checked all components and my pedal does sit 2" higher. I guess the reason for the original question was that I recently put a new clutch pedal stop on my 65, and that made the clutch and brake pedal align. Just thought maybe I had an issue!
Don
gt350bp
