Opinions on this antenna
Started by aj, July 27, 2021, 08:28:18 AM
aj
Does this appear to be correct for 69/70 ?  Thanks.
TOBKOB
It appears correct to me... :)
TOB
1969 GT350 owned since 1970
Cable nut is wrong should be round type .
aj
Perhaps right antenna with wrong cable ??
The tube is most likely is too long. However the tube can be cut and end re crimped.
aj
I reckon I'll pass on this one.   Likely a couple years before the cake needs this candle anyway.
https://www.ebay.com/itm/304082091194?hash=item46ccb47cba:g:GMUAAOSwbGFg~smD
Will keep looking.  And thanks for the education.
Stillakid54
Recognizing the cost and difficulty in finding a correct original antennae, any suggestions for a more reasonably priced/available alternative?
68-2766, since 1990
69-2524, since 1992
Quote from: Stillakid54 on August 01, 2021, 09:30:01 AM
It is a tough part. It has been that way for decades. Be aware that lower priced(4-600.00) exact looking antennas come up for sale every so often however the parts that they are made with render the antenna inoperative . It looks concours correct but will not allow radio waves to reach your radio. It is for looks only. Here is one on Ebay  https://www.ebay.com/itm/324694498055  . Owners and restoration shops in the past replaced a broken or missing factory antenna with a Ford accessory full size car electric antenna . It looks similar but not exact to the top side of the collapsible factory antenna. Trunk side of course looks different. The switch is installed in a convenient ready made factory hole above the radio trim panel. Another replacement that is sold as for Shelby(not) it is a Ford collapsible antenna it has a C5AZ J engineering number.https://www.ebay.com/itm/402722926722   . It is for Galaxie. It is different in every aspect mast,tip lower half and coaxial cable but still looks similar.
