First day on the road
Started by Stillakid54, August 01, 2021, 01:55:14 AM
Stillakid54
With covid and life the 69 saw the first road day in two summers. Radio did not work, ran hot, and putting the driver rear window down the 52 year old glue finally gave way, but I had the window safely in my hands. It was a great drive!! Looking forward to tomorrow.
68-2766, since 1990
69-2524, since 1992
Jack4159
Sounds a bit like me when I go for a walk these days.🙂
mark p
Nice, I'll bet it felt great to be hear the roar from the pipes after all of that time  - Sounds like a "win"  8)
SChatman
West Coast Classic Cougars has a great YouTube video about how to fix 69 glue in glass!
deathsled
Does 70 glass work? I think it was screwed in at the bottom. Having a 69 Mustang coupe as my first car I well remember the glass and glue issues.
Engine revving to disturb
Quote from: deathsled on August 01, 2021, 10:16:40 AM
Bolt in glass was a common owner upgrade in the past. You have to change out to bolt in glass door  components. Also different shape of glass can be seen at lower end rear when door is open. You can tell bolt in glass or not because you have to change out the glass trim seal between the back of the door glass and quarter window so it will seal properly. Bolt in glass seal is different compared to glue in glass style. People typically fix the glue in glass now a days what with better access to improved adhesives , superior guidance on fix process and the trend towards originality.
deathsled
Quote from: Bob Gaines on August 01, 2021, 10:44:46 AM
You're totally awesome.  If you weren't already, you would have been a formidable forensics investigator.
Poor Ron
The drivers door glass in my 1992 F150 fell down a couple weeks ago.
Repaired it with some Flex Tape, as seen on TV.  Just cut a strip, put it
in the channel on top of bracket, pushed glass in, worked out OK. Just like on TV.
Quote from: deathsled on August 01, 2021, 01:15:37 PM
Thank you for the kind words.
Quote from: Poor Ron on August 01, 2021, 02:14:16 PM
practical, functional, my hat's off to you !
I used  a commercial epoxy from my local glass shop to glue in my original glass over 20 years ago. Still holding up. I'd recommend not going to bolt in glass and get a good epoxy or have a reputable automotive glass shop do your side glass. I'm going to pull my 1969 SCJ Mach1 out into daylight today for the first time in 6 years. Install a passengers seat and readjust the passengers door. Been doing body tweaking on it since I started redoing the engine bay 6 years ago! Most work done in the last year.
Stillakid54
Summer slips by quickly on the Prairie provinces. Since the first post: overheating was not (simple sensor issue), all the glass now re-glued and properly aligned. As to the radio, had simply forgotten to extend the aerial ( not something we have to do in cars for the last 30+ years), so all good.  Beautiful day for a drive.
68-2766, since 1990
69-2524, since 1992
