Rear panel G.T. 350 emblem variations
Started by 6s1640, August 07, 2021, 02:38:55 AM
Have found some emblems with threaded pins and different styles of nuts. Haven't seen a confirmed example with nuts being used on the 66. Different nuts and style fo threads lead me to believe that the nuts were likely someones better idea - not the plants
Not sure how many pictures I have of unrestored cars but will see. Have a few hours to go looking up another detail for another thread
DennyD
From examples that I've been able to I review, Cory's last photo shows original the assembly line style of Tinnerman nuts that were used to hold the emblem in place. Thanks Cory!
I have seen something like threaded pins before . In my instance what first looked like threaded pins to me on further inspection of the several that I have seen over the years was when a shell nut was used to secure the plate would cut a groove into the pin as it was screwed down mimicking threads . I do not think that the shell nut was a factory installation. It makes the most sense that the easy to install and common tinnerman push nut was the typical installation.
     I removed the plate on 477 for the first time in '74 when I had the car painted. It had the "speed nut " pictured. In all my years the Tinnerman nut has been the most common too. I have only seen one other with a speed nut. Oddly it was a very late car in the 2300's.
Found a few photos of my original and replacement emblem
The differences are a lot
deathsled
Quote from: Steve McDonald Formally known as Mcdonas on August 22, 2021, 02:31:48 PM
I'd put the old one back on...
Engine revving to disturb
Some of the plates were made of a material that dulled like pewter and in some cases very quickly. Consequently the fix was to paint the surface with silver paint the black letters were course the same. The material was later changed and so painting was not needed.
deathsled
kingchief
You should get MORE horsepower by putting the original back on!  8)
Steve
SFM 6S406
Tired Sheep
Not sure it is fair to call the Scott Drake emblem a "variation"
Not much of what they produce is correct. I am a little surprised his name is not on the outside of the emblem.
Quote from: Tired Sheep on August 23, 2021, 08:46:33 AM
If anything, it should be referred to (with others) as a "reproduction variation or style" If just "variation" is used someone may interpret is as being an original variation or option
Blurs the lines I believe
S7MS427
Quote from: J_Speegle on August 23, 2021, 04:30:13 PM
+1
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Was showing the difference  between my original and what was able to find as a "replacement" emblem.
On the original I was even able to save the push on clips to reinstall it.
