Headlights and dash lights
Started by Shlby68, August 15, 2021, 08:10:32 AM
Shlby68
Drove my car home first time with headlights on, after about 5 minutes my instrument lights went out and back on several times,then my headlights were going off and on, parking lights and tail lights not affected.
Any suggestions, has new battery and voltage regulator
Thanks, George
Corey Bowcutt
That happened to me and I replaced the headlight switch and it fixed everything.
Corey
67 GT350
Yup, headlight switch. Crazy but true!
Should be an "EZ fix"
RARE  Signature Delete
This happens a lot if you installed Halogen bulbs. The circuit breaker for the system is built into the headlamp switch. Halogen bulbs are right there at the max current the switch and wiring can take. Often this results in darkness while driving.
If you have standard conventional sealed beams then it might just be a bad switch.
S7MS427
If you have halogen headlamps, try replacing the incandescent bulbs with LEDs to reduce the load.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
