66 fiberglass hoods with steel frames
Started by 64cobra, August 19, 2021, 11:57:14 AM
SFM6S087
Randy, thanks for sharing your opinion on this hood. I have long suspected that this is a "later" hood based on the "gussets" under the leading edge. But I never knew that there was a difference in the scoop opening. What fun this is learning something new!
If your trouble with photos is posting them to the forum, feel free to email them to me and I'll post them here for you. My email address is in my forum profile.
If anyone else has some pictures of the scoop opening on the "early" fiberglass over steel hoods, please jump in and post them.
Steve
      Steve ,
          I am not smart enough to own a smart phone and my flip phone is erratic at best. Plus the car is in the hauler at the moment. I'll work on it as this is key information.
Did look through my pictures - lots of them though as expected not an area of the car many people have taken pictures of. Can offer the following two examples that appear different from one another. Of course during "restorations" and repair the opening has been modified (some pretty ugly) and no longer look like originals
Hope this helps in some way
Not an area I've spent much time looking into or at
    Jeff ,
      Thanks as always! The gold stripe is similar to mine and the blue stripe is similar to the later hood although I can't see if the hood extends into the scoop area like the gold stripe hood.
The example with the gold stripes is from an early car in the just less that 6S500 range and the blue striped is from the early teens
 Makes sense as mine is 477. Mine has never been "body worked" in the scoop area . The pictures ( when I get them ) will show the details I talk about.
SFM6S087
Jeff, Thanks for the pictures, and the info about which scoop is the early and later version.
Jeff & Randy, Thanks for adding to my education!
I'm now reasonably convinced that the early hood version had the deeper scoop opening like the gold hood Jeff posted, along with NO "gussets" under the leading edge. And the later hood version had the shallower scoop opening like the blue hood Jeff posted, along with the 4 "gussets" under the leading edge. Does anyone disagree with that? Have I gone off the rails with that generalization? Maybe those two features do not need to be linked to each other?
Also, has anyone linked the clocking of the hood pin plate rivets to these two hood types? Could the 12-3-6-9 clocking go with the early hoods and the 2-4-8-10 clocking go with the later hoods?
Steve
See no reason to thing there is a link between the the clocking of the hood pin plates in 66 with the style of hood be it fiberglass and steel early, late or steel in its different versions.
Going to have to think and digest your other statement before offering an opinion :)
GT350Lad
#23
Might be a bit off topic but what about the replacement or NOS hoods of the era? If an original was damaged. What are they like? Like the late style?
Cheers
6S373
6S1276
