Mico cylinder repair
Started by hertzdonut, September 10, 2021, 07:15:13 AM
hertzdonut
Does anyone have a repair kit for an original 704B Mico Cylinder for sale?
Terry
C Griffith
If possible find a MICO dealer in your area.  I use Fluid Power Inc. in York, Pa. 717-252-1535 Jaldinger@fluidpower.com
You will be looking for MICO repair Kit # 02-001-029.  Big blue top vent plug may need to be replaced as they use a different
high pressure relief valve in the new kit.  Replacement plug is steel not original aluminum.  Good Luck Terry
hertzdonut
Thanks for your help. I've been looking for another part #
Terry
OldGuy
Quote from: C Griffith on September 10, 2021, 08:43:18 AM
If needed, you can modify your original aluminum top plug for use with the modern-day pressure relief valve. It is a simple machining operation which will allow you to maintain the original appearance of your MICO. If you want the details, send me a PM and I will furnish you with a drawing that illustrates the modification.
Frank
C Griffith
Forward the drawing to me please. I still have the original plug and can use it as a spare. I had a few plugs machined and anodized since mine was marked up.
Thank you, Charlie
