New to forum. #682
Started by VKF62, September 18, 2021, 12:10:35 PM
  Quoting Kermit:  it ain't easy being green.
    Anyway, nice looking car.  Now, who snuck that T-pan under  the engine?
Chad
Very Beautiful car!!!  Congrats
VKF62
We did make some upgrades to the rotating assembly. Roller cam/Roller rockers / balanced - blueprinted. Made mid 400s at the crank on dyno
Shawn
Congratulations and love the color
TA Coupe
How many cubic inches and what is the compression ratio? What have been done to the heads and are you using stock ones?
       Roy
If it starts it's streetable.
Overkill is just enough.
VKF62
Sleeved all 8 cylinders back to stock bore. Stroked crank. Don't know exact cubic inches, but I think it's around 468. Compression is 10.5/1 or close about. Designed to run on pump gas. I have original heads but we are running 68 cobra jet heads that were ported and polished. Roller top and bottom. It runs very strong but keeps a stock look.
427heaven
Welcome to the crazy world of SAAC, and some crazy opinionated sumbitches. At least its never boring around here. I for one love your car with the right look, stance, and some extra ponies under the hood. Dont just say hello and leave, we NEED some fresh faces around here.!
mark p
Side-Oilers
Great car!  I like the Lime over Parchment.   Welcome to the gang.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
BeaterGT500
Welcome!  I have 683, also parchment interior, but Brittany Blue.  Nearing the end of the long, dark tunnel of a rotisserie Resto.
TA Coupe
Quote from: VKF62 on September 19, 2021, 01:45:37 PM
Did you mean to say mid 500hp? I have a 302ci engine with 10 to  1 compression a good cam and 2x4's that's making exactly 400hp so mid 400's seems awfully low to me especially for 468 cubes.
       Roy
VKF62
Not all dyno readings are the same. Depends on the dyno being used. Some give a more generous reading and others can hurt your feelings. I feel mid - higher 400's is about right. A 427 would make more power. This reading on a 428 with upgrades mentioned is where it should be.
oldcanuck
Is it just me, or..... did SAI have a run on parchment interiors in the 0675 to 0725 range...... ?
Bob
Knoxvegas, TN
Quote from: oldcanuck on October 08, 2021, 08:11:10 AM
Yes, DSO 2536 (of 105 cars - all BB 4-spds - which that range of cars was in) included 73 cars with parchment interiors.
DSO 2538 (also BB, 4-spds) 57 of 61 cars were Parchment
DSO 2539 (BB, Auto) 14 of 15 cars were Parchment
DSO 2540 (BB, Auto + Thermactor) 16 of 18 cars were Parchment
Richstang
A total of 257 units were built with parchment trim/interior.
Only 20 were GT350s. The majority were Big Blocks ('BB' as JD mentioned, also an acronym for Brittany Blue)
The Shelby VIN sequence range was much wider than 0675-0725. However,
Ford SJ build dates for parchment trim was limited to January 1967 until March 1967 with one unit exception in May.
Typically each DSO was built with the same engine/trans package and trim color. They only varied in paint colors.
There were a few DSO exceptions as JD noted above. Those were DSO 84-2534, 2536, 2538, & 2540
(An SRG topic lists the in depth details)
https://groups.google.com/g/shelbyresearch/c/43mJlQH5qL0
JD, all 15 units in DSO 84-2539 had parchment trim.
1967 Shelby Research Group
www.1967ShelbyResearch.com
