Traction bar adjustment?
Started by Tomdeg, September 20, 2021, 09:49:36 PM
Tomdeg
Hey Gang,
On the under rider traction bars there are a stack of washers. Are they there for adjustment/alignment?
If so, what is the procedure for that?
Thanks in advance
Quote from: Tomdeg on September 20, 2021, 09:49:36 PM
Hey Gang,
Thanks in advance
I am not sure if the washers only have one function but the bar should be square with the frame . Sometimes the frame bracket can be welded on slightly off . The amount of washers can help compensate for that.
Tomdeg
I have another question. The bolts on the welded in forward bracket tilt up. Is this normal or should they be perpendicular? It seems to me that being on an angle like this would cause a rotational torque and put pressure on the bushings.
Quote from: Tomdeg on September 23, 2021, 10:13:56 PM
Not tilted typically. Most likely bent upward from using it or close by as a jacking point IMO.
