67 Shelby GT350 Front Spring stripe color?
Started by dhardiman, October 05, 2021, 12:16:20 PM
......but what are their stripe color id's?
texas swede
DSO 84-2555 has C7ZA-5310-N. 4-speed Non A/C with Thermactor 402F.
Texas Swede
Quote from: shelbydoug on October 15, 2021, 01:43:11 PM
Not knowing which group/order the OP car fits into and without knowing if we have copies of those sheets available I guess at this point we're left with the possibility that the car as described used the -C7ZA-5310-AN Springs
From other cars matching the same details I've got one lavender and one yellow. The odd thing is that the same colors have been found on other combinations with different part numbers so there may be more variations in the spring part numbers for other order groups
lawrence67
No response to question in reply #15 yet.
PL
Richstang
Quote from: lawrence67 on October 19, 2021, 11:30:33 AM
PL
The new part number lists suggest that detail needs to be looked at closer for an answer.
It's best to follow the previous suggestions to leave them off and avoid points deductions for incorrect markings.
1967 Shelby Research Group
www.1967ShelbyResearch.com
PL
Thought I address that in reply #17 but as mentioned if your worried about showing and are entering Div II or a Concours class the safe bet is to apply nothing if your unsure. No deduction for the lack of markings and you won't lead someone else astray if they choose to copy your car assuming that you knew for sure
