Big Block Fan Shroud Repair?
Started by FordGT, October 14, 2021, 10:55:54 PM
FordGT
I have the original big block fan shroud that is dark brown, looks like horse hair and it got broken in half.  Has anyone ever glued one back together?
If so, what glue was used and did it hold with all the vibration?
68blk500c
They can be restored, but it takes more work than just glue.  Make sure yours is the factory version (Ford # suffix) or it may not be worth the cost.
Yes I have done it. It is a slow and labor involved process. Took me over a month to "properly" make a complete split look undetectable. I used an "industrial" superglue that when mixed with crushed original material allowed the horse hair to be seen. It took several applications and lots of "forming" the area.
FordGT
Yes its an original with C7ZE-8146-A on the left top flange .  Do you remember what industrial glue you used?
Also, have you had any problems with re-cracking because of the vibration?
Quote from: FordGT on October 15, 2021, 04:38:16 PM
Also look for the FOMOCO trademark. Some of the older repros that looked good otherwise had the number but not the Ford trademark like original. The repro also had fiberglass weave mat texture on the inside and not smooth like original.
        I do not remember. I bought it from a "Hawker" touting it's wonders at the Pomona Swap Meet and I ponied up for a bottle. It has to be refrigerated but is FAR superior to any "store bought" super glue.Three years later it is still excellent. It is liguid , not a gel which requires "filler material" harvested from another "horse hair" shroud , Ford truck in this case. ALLOT of filling and filing along with multiple applications , but it IS undetectable to the naked eye. Yes the horse hair shows through and can be "placed" to match the surrounding area before applying the glue.
Human hair as in what gets swept up on a barbershop floor can be used to help disguise a repair on a genuine shroud.
Quote from: Bob Gaines on October 18, 2021, 12:30:31 PM
       Especially from "gray hairs" like ME!   LMAO.  Human hair is actually thinner than the fibers in the shrouds. Gray moustache hairs are closer and they don't change color.
427heaven
Hopefully no man scaping was involved the repair of these shrouds. :-[
Or take your scissors on a trip past the stable
427heaven
Since I am in need of the same thing, when I head on down to the barber shop (pun intended) What hair scraps am I looking for texture wise... Blonde, Brunette, or Redhead? ;D
Quote from: 427heaven on October 18, 2021, 10:58:59 PM
Just sift through all of them and pick out the straight ones . :o ;D
427heaven
Ok, no curlys and semi coarse texture. Will report back with findings. ;D
FordGT
Going with the curly ones............
Thanks for all the help...
