HiPo block, Boss 302 block, 5.0 block, '57 Ford banjos
Started by sicvic, November 12, 2021, 09:43:10 PM
sicvic
6-bolt HiPo block with caps and bolts. D0ZZ Boss 302 block with caps and bolts. Both are rusty and may need sleeves. $350 each. 1990 5.0 block, standard bore (.001 to .002 over per machine shop), clean (coated in grease when put away). $250. 2 '57 Ford banjos with axles. Will throw in 9" center section of your choice with each. $350 each. Can text photos. Blocks are in Uxbridge, MA and must be picked up by 11/22. Banjos are in Sudbury, MA. Vic (508) 868-5105
Fastback66
