Seat covers, original or not?
Started by DennyD, May 01, 2018, 12:05:01 PM
Quote from: 6S1568 on May 01, 2018, 06:03:34 PM
Thanks everyone for your input on the seat covers.
Brain, I see where Carroll Shelby's signature is located on the seat foam. I tried to snap a photo of it, but the signature has fadded and can't be picked up by my camera lens. You'll have to take my word for it!
Next, to Side Oilers, I always wondered whose butt imprint was embedded in my seat covers, thanks for that!
Bob and Cory, I've posted a couple photos here for you guys to study. I do see the blue thread that you mentioned. I'm not sure about the beading size since I don't have anything to compare it with. Perhaps you can tell from the photos.
Randy, are you well pleased with your covers from Distinctive Industries? Where did you get them?
Brant, thanks for posting the photo, those seats look perfect to me.
Cory, I'll try to get photos again once I've removed the covers. I wasn't aware of the wires that run through the burlap. I'm guessing that you're correct in that most reupholster shops don't do it.
Show the top side because that is the most important part IMO because it is seen. The bottom isn't seen once installed. The top side is also the easiest way to tell if original or like original (in the case of a concours recover) .
DennyD
Quote from: 6S1568 on May 01, 2018, 08:51:49 PM
Top side photos.
Notice the smaller diameter inner welting in comparison to the larger diameter outer welting. The contrast diameters are what is seen in original seat upholstery. Although the upholstery looks typical the seat bottom appears to have been over stuffed at some point by a PO.
DennyD
Bob, Thanks so much for your input. I now see what you mean by the smaller diameter inner welting in comparison to the larger diameter outer welting. Denny
NEFaurora
#19
A fast, easy way to tell if its an Original Ford Seat cover is that if you turn the seat over, The bottom material will have cloth "stretchings" for the listing rods (As Brants's first and third pics show plainly illustrate on his original seat) where you hogring the hogrings.  No Repro seat covers ever had these cloth "Stretchings"... All Repro Seat covers just continue the vinyl material to the end where the hogring holes are and don't have cloth material sewn on for the listing rods.  The repros have like a felt material (not cloth) used for the listing rods just sewn to the vinyl.
:o)
Tony K.
The welting is the little bead visible between the panels. As Mr Gaines stated, if you look closely the welting is different diameters. Once you know that, its easy to spot.
Some of the repro 'welting' is made with the vinyl that matches the seats instead of solid plastic like originals.
ramrace
It is my understanding the welting on original seats was extruded, after market seats have a rope type material covered with vinyl. Thoughts?
Brant
As Charles mentions, the original was not a vinyl covered cord. I think there is a possibility that some brands may still be using this wrapped cord.
We handle TMI upholstery, which uses a much nicer cord than the wrapped stuff.
You can also see that the "inner" cord around the insert of the seat is much smaller than the outside one.
-Brant
