Radio power wire extention C5DB-18A919-A - Connector colors yellow or black?
Started by 6s1640, November 19, 2021, 03:37:24 AM
Hi all,
Below are two radio power wire extension images that have been identified for the early GT350's and Mustang.  Any ideas why the two colors on the connectors, yellow and black? Both wires shown below are part marked C5DB-18A9149-A.
Is one early and the other late?
Is the difference on the build plant?
Is it a supplier difference?
The wiring diagram that I have shows this wire as Yellow-Black.  That should be the color of the wire, not the connectors and wire.  The wire appears to be black with no striping.  Any thoughts?
What is the assembly line wire color and connector color for 1966 GT350's.   Would this wire have been installed at Hi Performance Motors with the radio?
Quote from: 6s1640 on November 19, 2021, 03:37:24 AM
Hi all,
The yellow end one is what you typically see as a service replacement.
